Fixing headlights comination switch?
I came to the same conclusion as to this problem with all of our aging light switches. The plastic on mine was also very worn but not to the extent as yours. I solved mine by putting a small ball bearing behond each of the springs. This had the same effect and also slightly increased the tension exerted on the rockers.
FWIW
  • Who's Online   2 Members, 0 Anonymous, 1,464 Guests (See full list)
