Hi guys
for the 240K people... do you know what's the max width of wheels I can fit on to my 240K coupe with no major modifications?
I'm thinking of getting 18's with 40 or 45 series tyres and probably 225 - 235 wide. It comes up that the outer diametre is close to what I have right now which is 185/75/14 but not sure about the width
need help guys
thanks
https://www.classiczcars.com/topic/9869-max-width-you-can-fit-on-240k/
Hey man,,
I run 205/55-15's on all four feet on my K.
The front are pretty close to touching the front struts or the spring perch at least and if she was low at the front she'd prolly rub the fender arch lip.
The rears are probably 5-10mm from touching the rear quarter arch lip but because of the IRS it never rubs, obviously there's a bit more room inwards than at the front so you could have wider on the back with the right offset.
The wheel size and offset figures from the Watanabe website are as follows;
Recommended:
F/R B 14-65 +14.5
Both Front and Rear, B-type Wheel 14x6.5" w/ a +14.5 Offset
Maximum conformity:
F/R F 8 15-65 +14.5 RST
Both Front and Rear, Forged 8 type Wheel 15x6.5" w/ a 14.5 Offset
2000GT-R due to the flares has different sizes again, but those are the numbers you're after ie. "without major modification".
  • Who's Online   0 Members, 0 Anonymous, 1,210 Guests (See full list)
